Good points.
Processors can analyze data very quickly though. There is also already a wifi standard for autonomous vehicles coupled with the fact that 5g cell service will make data transfer much faster, among other advances.
3d gaming isn't really "premade models", that's the whole point of gaming, it's not a movie. It is completely variable each independent input doesn't necessarily happen in the same sequence or at the same times. Modern PC's can run some of the most advanced games at over 60 frames per second which clearly shows the amount of data capable of being processed in extremely short periods of time. I'm not phased at all about the capability of processors for autonomous vehicles.
With more accurate GPS and known good routes "learned" in real or near-real time, I don't see way-finding to be an issue.
I'm a bit more optimistic than you are about AV I suppose. Way too much money on the table to not happen in the next 5 to 10 years.
