12-11-2018, 09:28 PM
#767 (permalink)
August 15, 2018,
https://phys.org/news/2018-08-intera...rodynamic.html
When engineers or designers want to test the aerodynamic properties of the newly designed shape of a car, airplane, or other object, they would normally model the flow of air around the object by having a computer solve a complex set of equations—a procedure that usually takes hours, or even an entire day. Nobuyuki Umetani from Autodesk research (now at the University of Tokyo) and Bernd Bickel from the Institute of Science and Technology Austria (IST Austria) have now significantly sped up this process, making streamlines and parameters available in real time. Their method, which is the first to use machine learning to model flow around continuously editable 3-D objects, will be presented at this year's prestigious SIGGRAPH conference in Vancouver, where IST Austria researchers are involved in a total of five presentations.....................
The researchers also proved in their study that the machine learning method achieves an impressive accuracy, a prerequisite for engineering. Nobuyuki Umetani explains: "When simulations are made in the classical way, the results for each tested shape are eventually thrown away after the computation. This means that every new computation starts from scratch. With machine learning, we make use of the data from previous calculations, and if we repeat a calculation, the accuracy increases."
