Fall semester of college is over, and I'm back home for the next 4 weeks on break before the spring semester begins. This means...Insight time!
Reused the foam from the Civic's grille block to make an upper grille block for the Insight. This will be temporary until I build the lower grille block out of coroplast. Then I'll just use the upper grille block on extremely cold days.
And yes, I know I need to touch up that front bumper.
Got someone test driving the Civic this weekend. Hopefully it goes well and sells. Then I can go ahead and purchase what I need to modify the Insight (Daox's switch knob, Natalya's FAS setup, Scott's belly pan, etc.)
Quick question: does anyone have a link to a WAI setup for the Insight? I want to build one and have no idea where to begin yet.
