Old 12-12-2018, 04:10 PM   #4065 (permalink)
aerohead
solar
https://www.energysage.com/solar/sol...-solar-panels/
I have provided sources showing that the average solar installation in the Phoenix area would cost $15,000 and have an ROI of eight years.
Enough batteries to run the air conditioning for three hours would also cost $15,000, making the ROI sixteen years--longer than the expected life of the batteries.
So, before you pay them off, you already replace them. If you replace them then the ROI is now twenty-four years, but that is probably longer than the batteries will last, and is approaching the anticipated life expectancy of the solar panels.
If installing batteries becomes 10% cheaper and they last 10% longer you should break even on them.
We're getting a little bit of utility-scale solar farms around here now.
Rather than deal with a home system,some are opting for the solar plan,and pay a modest premium to compensate the COOP for the land,hardware,install,maintenance,replacements,etc .,into the future.
