Having owned a '96 Ranger for about ten years, here are my thoughts:
1. This engine LOVES full synthetic oil, and it makes a measurable difference in fuel mileage. My favorite was always Mobil1.
2. I didn't have good luck with killing the engine to coast, but coasting in neutral gave me awesome mileage though.
3. This engine doesn't make enough power to reduce the rear axle ratio or run over sized tires.
4. Anything that you can do to reduce the effort to get this truck moving or keep it moving will make a noticeable impact on your mileage. Converting to an electric fan, pumping up the tire pressure, full synthetic fluids everywhere, lighter wheels/tires, aero improvements, etc all make a big impact.
Reason: remove incorrect engine specs
