I could / would not tolerate the bad tranny . I would start searching for a replacement + clutch + pressure plate + throw out bearing + pilot bearing + alignment tool .
If the clutch is hydraulic , I would check it and service / flush the fluid too . If not , examine / lube the linkage .
God bless
Wyr
