Old 12-14-2018, 05:28 PM   #3 (permalink)
cajunfj40
Lurking Eco-wall-o-texter
Hello Angel And The Wolf,
Interesting idea. You might want to read up on the Harley V-Rod/VRSC with the then-new liquid cooled 60-degree DOHC engine. They did a lot of work on the exhaust system with a resonating cavity connecting the two pipes to try and get as close to the old 45-degree engine sound as they could.
Got any links for that California Quad Exhaust? I'm not turning up any "true 4-pipe" exhausts for anything but exotic V12 Ferrari and Pagini vehicles - and those are 3 into 1 primary with 4 secondaries, not what you're describing.
Ok, more searching dug up old Stahl 360 degree headers for a small-block-chevy. https://www.jalopyjournal.com/forum/...ock-up.415461/
Firing order on an SBC is 1-8-4-3-6-5-7-2, so if you puzzle out that bundle of snakes, you see that the cylinders are paired up so that each pair is firing 360 degrees apart, so it would sound like 4 British parallel 4-stroke twins with 360 degree cranks, or 4 large single-cylinder 2-strokes.
I'm not sure how much power you'd lose without balance tubes compared to OEM cast-iron manifolds, unless you're starting with pretty decent OEM ones, since the pulses are nicely separated in each merged pipe - flow balanced. Do your homework on correct primary diameters and lengths, etc. and you can probably meet or exceed OEM output, using 4 separate smaller catalytic converters. You'll need to pick two spots for your O2 sensors or figure out how to "average" a pair of O2 sensors into 1 output that the ECU will feel OK about. I'm assuming a new enough engine that there's an O2 sensor for each bank of your V8. (Secondary post-cat sensors not included.)
Your second idea with the 4 short pipes to the O2 sensor *might* work, but you could be putting too much delay in the mixture feedback loop. Depends on how well that setup flows across the sensor, and with balanced pulses there might not be much flow. I think the first idea would work better in terms of getting a good mixture read.
On a standard "dual" exhaust with 4 into 1 headers on a common cross-plane crankshaft V8 needs the balance pipe because of the uneven firing order on each bank, which messes up the scavenging and causes unbalanced flow out a dual exhaust. 180 degree headers would mimic a flat-plane crank - quite a scream if you've got a high-revver - and don't really need a balance pipe because they're already flow-balanced and scavenge like a pair of inline-4 engines. Those headers are aptly called "bundle of snakes" because of how difficult it is to get all the pipes to where they need to be.
Either way, you're welding up something custom or having a shop do it for you, so cut and try will probably be what you need to do. Use the old converter for the trials, or a cheap aftermarket job if you want clean steel to start with. Once you figure out what you want, get a good unit and set it up.
Have fun!
