Old 12-15-2018, 01:26 PM   #9 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by Daschicken View Post
The chain will spin slower actually
Umm...no.
If you have a 16 tooth sprocket and the output "shaft" it's attached to is spinning at 200rpm, the chain is moving 3200 links per minute. (16x200)
If you have an 18 tooth sprocket spinning at 200rpm, the chain is moving 3600 links per minute. (18x200)
You will, however, be spinning the engine at a slower RPM for the same speed, which is probably what you're thinking.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
Frank Lee (12-19-2018), Xist (12-17-2018)
