Old 12-15-2018, 07:03 PM   #5 (permalink)
freebeard
Depends on how you search. If you go to his home page it listed first.
I’m mainly not sure how the Template should be overlaid on my car.
It shouldn't. Look at it from the end, it's a half-circle. You are starting with an existing cross-sectional profile. Six inches of taper in 4 feet is you limit. If the top tapers faster than the sides air will migrate upward and potentially induce vortexes.
A smooth transition onto a compound curve will do the most good. How does the cargo load, from the rear or side?
I've try to get some material on boat tail vs box cavity vs retractable base plate.
aerohead (12-19-2018)
