Old 12-17-2018, 11:43 AM   #6 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Vman455 View Post
I "live" out of my car for up to 2 weeks at a time during my summer travels; it's much, much cheaper than using hotels, I get to see interesting places, and there's a feeling of freedom travelling that way when you aren't tied down to a fixed physical location.
I don't bother with cooking; I just eat cold food on the road, like yogurt, fruit, vegetables, sandwiches, etc. Shower at truck stops ($10-12 for a shower, and national chains like Pilot are always impeccably clean) or, now, I have a Planet Fitness Black card so I can go to any PF nationwide and shower.
Finding a place to park is the hardest part. I like to use Walmarts--3/4 of them allow overnight parking (google "no park walmart")--or campgrounds. I've never tried stealthing it on the street; that seems like inviting hassle from the police if you're discovered.
One of my projects over winter break is to add some thermal insulation to the cabin to make it more comfortable to sleep in, and revising my window blocks. They're currently just Reflectix cut to fit the windows, so I'm going to back them with 1" XPS board (R-5.0). In the doors and behind interior panels I'm fitting 1.6" denim insulation (R-6.7) and Reflectix radiant barrier. This should slow the rate of heat transfer at least a little--better than what's there, which is nothing.
The first year I camped this way, I took along a cooler, but last year I bought a 12V cooler/heater. Much easier; I don't have to bother with buying ice and draining water. The Prius' 12V socket will run up to 10 amps, more than enough to run the cooler and charge my cell phone and laptop with a little 100W inverter plugged into it.
(Glacier, 2016)
Honestly you're not wrong. I'd say the Prius is a little more basic than I would like for anything over just a weekend stay, but personally but as a weekend vehicle, it isn't all that bad. All personal preference on how much of a minimalist you consider yourself.
What cooler do you have? Have you measured amp draw on it? I've heard a lot of the cheap ones really use a ton of Ah's to stay running. I've looked at alpicool. I think one of those wrapped in more R rated foam would be a sweet option to use.
Do you use any of the insulated winter sleeping bags to help with the temperature control?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
