Old 12-18-2018, 12:51 PM   #9 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by hayden55 View Post
Honestly you're not wrong. I'd say the Prius is a little more basic than I would like for anything over just a weekend stay, but personally but as a weekend vehicle, it isn't all that bad. All personal preference on how much of a minimalist you consider yourself.
What cooler do you have? Have you measured amp draw on it? I've heard a lot of the cheap ones really use a ton of Ah's to stay running. I've looked at alpicool. I think one of those wrapped in more R rated foam would be a sweet option to use.
Do you use any of the insulated winter sleeping bags to help with the temperature control?
I use a Wagan 24L, not large. It only draws 3.5 amps, and it only cools something like 30 degrees F below ambient.
I use a 20F Slumberjack bag that I've had forever. It's plenty warm, but I think the added insulation to the car itself will both make it more comfortable to sleep in, and also reduce heating and cooling load when I'm driving.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
hayden55 (12-18-2018)
