I wouldn't go crazy with gearing changes, as has been mentioned riding 5 mph slower will have a bigger impact.
If you go down a couple of teeth on the rear sprocket you could probably just remove a link or two from your existing chain. I use this calculator which helps:
https://www.rbracing-rsr.com/chainlength.html
