Old 12-19-2018, 10:22 PM   #29 (permalink)
Mrtony5
Welcome to the site man! Looks of great info here. Speaking from experience you have a great car. I once owned a 1992 civic cx it is the only car I miss as I put well over 150000 miles on it. The cx and vx have the same transmission gearing. Dx and lx are same. My cx motor blew up so I got a d16z6 and swapped it into it that's out of an ex. Then I discovered the vx and its wonderful mpg. I actually rebuilt the vx motor in my bedroom while I was at college because I bought it with bad rings. I think I spend about 200 on everything needed. First one I rebuild(have done 3 other motors more since) it was by far the easiest. Once I got it done I swapped the vx in my cx and paired it with my original cx tranny. It was a dog compared to the ex engine and tranny. But I couldn't complain went from 35mpg to 55 to 60 it was amazing.
Something to check for. Right behind your driver rear wheel there is a "gap filler" molded plastic box thing...hard to explain but it was only on the vx hopefully yours is still there. It will help with keeping air from getting into the rear of the bumper which will cause drag.
Your new car also has the wrong wheels in it. The vx ones where designed for areo and low weight at I believe 8 lbs each. I never found a full set for mine 😢
Congrats on the new purchase. There is plenty of info on honda-tech.com and YouTube on how to rebuild and what not for that car. Enjoy !
