Delivery you are in good hands here, these people know their aero! Do you have a receiver and trailer wiring plug? Not that hard to install a plug if not. Then you can plug lights in I think a legacy would be tricky to boat tail and keep access to trunk. Might be able to go lightweight kammback stuck to back door, which lifts up and out of the way. A box cavity is a simple sided box behind the vehicle inside the draft. Not as good as an aero boat tail. But help.help
Vman455 the Prius looks awesome with the aero hitch box tail, very slick.
