Originally Posted by Ecky
-I didn't move the Rocket Tabs over from my summer tires, so after I switched to winters I was running without.
-My 12v battery failed when the temperature dipped low enough that I needed snow tires. Supercapacitors are the real winner here.
Your best MPG on winter tyres (with SC) is still impressive compared to the other combinations
Best is above best summer tyre mpg, and lowest is higher than with summer tyres as well.
Let's see what the Tabs will do in spring, with SCs, but the only graph going downhill is the one with Rocket Tabs - not good ...
