Old 12-22-2018, 04:44 PM   #4251 (permalink)
aerohead
fans
Originally Posted by All Darc View Post
What about fans ?
Some fans also work as cooler when equiped with water mist system, since water while evaporates take heats off. But it only works reasonable in very dry weather
I don't use air conditioned, I use a fan on my side during hot weather.
Why americans are so adicted to air conditioned ?
For cold, people could use clothes for cold weather, insted of warm the home interior up to use light clothes. But I know some countries are so cold in winter that home needs warming system at least in some degree.
Around here they work up to a point,then with the relative humidity, it creates a heat index value which exceeds what is tolerable to humans. We can have dew points of 78-degrees F.Just sitting can cause exhaustion.
