Originally Posted by RedDevil
It may return in the future if home solar ever gets to the point that it produces more than the local network. One of the problems is that the grid tie converters monitor the power wave on the network to determine how to feed in the power.. Too many grid tie converters may cause instability.
But by that time the grid tie converters may well be orchestrated by the power company. They could be used to improve the shape, compensating for the cutoff effects caused by modern electronics.
They would not only provide power, but also improve its quality.
Not here. All of the solar power that goes on to excels grid has to go through an over the air controlled co-gen meter.
If the utility needs to they can remotely disconnect power from the solar panels in the event of an over voltage event. Which is unlikely.
