Old 12-23-2018, 11:55 AM   #3282 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by esali1987 View Post
Got the communication working!! Might have put the connector on the wrong side of the board. oops. With the throttle hook up i am reading 0-1023 going to both extremes.
throttle-type 1
stream-raw-throttle 1
data-stream-period 100
is the commands i used. I am guessing this is what should happen. Next step is battery hookup?
0 - 1023 is GREAT for the throttle signal. My throttle does not make it all the way to either extreme.
It's been a while since I started from the base firmware but I think the defaults work OK with a low voltage pack. The response is a bit slow but that's fine for testing.
It would be great to see the outputs to the IGBTs on a scope to make sure they don't overshoot too badly. Paul has the resistor values dialed in to prevent that .. but it's one thing I'd check. After checking all 6 outputs, it would be time a test with low pack voltage.
You can connect your AC motor and just check the output on your scope with low settings for max battery amps.
Your AC motor will spin with lower voltage, but it takes a certain minimum current so don't be surprised if you're pushing about 1/3 of your rated amps before it starts to spin.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
esali1987 (12-23-2018)
