Old 12-24-2018, 11:28 AM   #4279 (permalink)
All Darc
Aircrete could be a good alternate building system for Brazil, since here portland ceament it's quite less expensive than in USA.
But one thing I don't understand.and sound foolish, maybe my ignorance : Ceament it's a kind of glue to connect sand or sand and small rocks (concrete). How can just the "glue" alone work as a material, resistent ?
Aircrete it's just this "glue" and air.
yes,it was cellular concrete.He used DuPont 'Duponal' surfactant,with a very strong surface tension bond.
The surfactant was diluted in water,then forced through a foam-gun (Valved PVC tube full of stainless steel mesh),under about 150-psi air pressure,and injected into the back of a Ready Mix truckload of 8-sack,sand mix,and mixed in.The bubbles are so strong they survive the torture of the mixing and ram-forced passage through a concrete pump and hose.It's trippy stuff! Hollywood special effects!
The Following User Says Thank You to All Darc For This Useful Post:
aerohead (12-26-2018)
