Old 12-26-2018, 07:21 AM   #9 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by Piwoslaw View Post
My new e-HDI engine has an AGM battery for the Start&Stop feature. I'm looking for info on how to charge it to keep it healthy.
What do you think? Is 3.8A @ 14.7V better for my new AGM battery than 0.8A @ 14.4V?
It should help keep the cells better balanced than a lower voltage, in theory.
Not sure if AGM need the voltage to drop off(down to 13.8) after 80% SoC is reached, but I would assume so.
If you want any kind of lead acid to last a while, try and avoid letting the SoC drop much below 50%. You can get ~1000 charge cycles that way, rather than 2-300 if you drop it down to 20%. I'd also avoid pulling more than ~1C out of the battery for more than a few seconds at a time.
Back to your regularly scheduled programming...
