Old 12-26-2018, 10:19 PM   #110 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
I'm unaware of any SUV with a 165 width, those are probably the right ones. Nokians are definitely heavier than RE92s which are ~13lbs each. Nordmans?
Nordman 7s. Link:
https://www.ebay.com/itm/4-New-Nokia...4/263395936092. Seller says they are non-studded - photo is a stock photo. There hasn't been any snow here, just cold weather, and I'll be returning to Virginia in about 2 1/2 to 3 weeks; I'm kinda thinking on passing on the winter tires and just keep running the RE92s..
Originally Posted by Vman455 View Post
You shouldn't need any resistors to make LED turn signals work, just replace the thermal flasher relay with an electronic one. They're cheap and readily available. On my 2005 Civic, the fuse panel with the relay was the one beneath the steering column and to the right; might be in a similar place on the Insight.
Is it worth it though? I've heard that's fairly hard to access on the Insight. Especially since turn signals aren't on much so the electrical savings would be minimal compared to the cost of the LEDs.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
