Old 12-28-2018, 05:11 PM   #37 (permalink)
Xist
Someone please look at this image again.
Yes, the odometer reads 1/3 higher than we were led to believe, but if I may direct you to the light on the left that says "Check" and is shaped like an engine and the one on the right that spells "IMA." Perhaps the one in the top left that spells "SRS" is of import, too.
Rainsux on InsightCentral says all that matters is the traction battery, second-gear syncros, and the RE92s, but since they are only asking $1,500, he does not care. Willie Williford suggested that I contacted Rush who lives in Tucson. Rush is unfamiliar with a white Insight with fender damage, pointed out the lights that seemingly everyone else missed, but wrote "For 1500 or less it is probably worth it."
