Old 12-28-2018, 09:32 PM   #3288 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by esali1987 View Post
I now have a good throttle signal and HV hooked up to the IGBTs. Phase to phase I dont get any signal and I am not really sure where I should measure to see the control voltage from the IGBTs. Can anyone help with this? Thanks!
Sorry - I didn't see this as a new post for some reason
Agreed - voltages should swing from slightly negative (-3V or -5V) to about 15V.
I don't have access to my controller - it will be Jan 2 before I can go home and look. I should look at that in any case to determine if I killed my control board when I killed my IGBTs, or if I just killed the IGBTs.
The IGBTs are driven (or they were in my version ) by through-hole connections direct to the IGBT pins. I don't remember how many pins, or what the signals are for each. That's what I'd have to look up.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
esali1987 (01-01-2019)
