Old 01-02-2019, 01:47 PM   #30 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Vman455 View Post
If your plan is to work temporarily in an area, your best bet might be to skip the electric accessories and invest that money in insulation to make the van a more comfortable living space, which wouldn't be nearly as expensive as the mechanical work. Then get a cheap bike and use that as a local commuter if needed.
I agree with you there. Goal is to get a white van that doesn't look to beat, and insulate it heavily with poly foam.
For the most part the mechanical work should be cheap. Like 100$ junk yard rear axle, 10$ electric fan etc... lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
