Old 01-05-2019, 11:42 AM   #16 (permalink)
Piotrsko
If you have a clock spring, it is easy to install a late model multi switch steering wheel. You will need an appropriate new clock spring unless you are really good at removing. I believe you have to do semi major alterations on pre 2000 vehicles.
