Old 01-05-2019, 12:44 PM   #17 (permalink)
racprops
If you have a clock spring, it is easy to install a late model multi switch steering wheel. You will need an appropriate new clock spring unless you are really good at removing. I believe you have to do semi major alterations on pre 2000 vehicles.
Thanks, but I am told with a 2003 CV I can just pop out the cruse on/off switch and add the one with both cruse and volume controls as they were pre-wired for them, and that the clock spring is also pre-wired. I will just need to find the correct wires to change where they go and hook them up to my controller.
Rich
