Old 01-08-2019, 01:30 AM   #19 (permalink)
jeff5may
Send a message via Yahoo to jeff5may
Ok, so per the wiring schematic you posted, you should be able to control the fan at will while the ignition is on. Use the Blu/wht wire at the underhood junction box or at the a/c thermostat. Splice into the wire and run a control wire to your switch. Ground the other switch terminal. The end. Low power control of what have you.
The Following User Says Thank You to jeff5may For This Useful Post:
California98Civic (01-09-2019)
