If you slow the engine down too much you fall out of its efficiency range. Even worse yet, combustion and crank shafts harmonics tear up the rod bearings.
Figure out the lowest recommend cruise rpm and gear for that.
Pushing the operating range down to say 1,000 rpm is just going to ruin the engine.
