Old 01-11-2019, 09:58 PM   #155 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Yet some are replaced under warranty. I cannot find any data on how long they last on average. The ones that I see on Craigslist either have bad traction batteries or aftermarket ones that will not last as long as the originals.
Some engines are replaced under warranty but that doesn't mean it is a common occurrence.
Toyota warranties batteries for 10 years / 150,000 miles. If for some reason the battery failed out of warranty a brand new one from Toyota is only $2600 and requires 2 hours of labor to swap. That might sound like a lot but how much does a modern 6-10 speed transmission cost? (The Prius doesn't have a transmission but instead uses a single planetary gear set)
If you don't want to worry about a battery the conventional ICE Accord is good for 32 mpg. 45% better then 2000 isn't half bad. I had a new 2019 Accord for a rental last month and managed 39.5 mpg.
The Following User Says Thank You to JSH For This Useful Post:
MetroMPG (01-12-2019)
