Old 01-12-2019, 12:49 PM   #158 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If you see 04-15 Toyota Pri's with bad batteries send them my way! It's not really a secret anymore but you can discharge and charge the batteries on a charger, measure Ah capacity remaining in the cells and keep the good ones and toss the old ones very easily. Rebuilding the pack of 28 cells typically cost a max of like 600$. Much less if you actually test your cells vs just tossing all of them. If you just do a swap of all cells I'd say a couple hours and you're done. Plus the cells are just in a rack vs spot welded like the damn Honda batteries.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
