Thread: HD Livewire
Old 01-13-2019, 08:02 PM   #19 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
In a straight line, it's not really possible to lock up the front wheel of my bike unless you grab too quickly before the suspension settles in. I can stoppie in the wet...
That is true with a consistent road surface. That was not the case in the situations I mentioned above. Both crashes happened at night while braking approaching an intersection. The first time I hit a patch of of fine sand, the second was an oil patch on a wet road. Both times the front locked and I was on the ground before I knew what happened.
