Old 01-14-2019, 04:55 PM   #88 (permalink)
Grant-53
Any form of surface in the front steering components is prone to cross wind inputs. I strongly advise against a front disc or fairing attached to the forks. You could survey the tests on aero rims and make a profile from light plastic tubing. I'd suggest a 6 ft dishwasher hose centered around the rim. Cut alternate slits to fit it between the spokes and make some spoke fins.
