Low weight and low dragh helps reduce energy used. Lower energy lower thermoelectric activity. Lower energy consume means less battery pack.
Solar panel on the vehicle also reduces the need of a lot of batteries.
The solar output, for home, matters if you think in reduce fossil fuel use.
Originally Posted by redpoint5
It's a viable product despite poor aero. There's no such thing as perfect, just good enough.
Doesn't matter if the solar output is enough because you connect the house to the grid.
If you missed my point somehow, I'll just tell you. Putting solar on the roof of a vehicle is beyond retarded.
