Old 01-16-2019, 02:07 AM   #7 (permalink)
westygo
Thanks guys.
I don't have much more in the way of pictures. To attach to the car, I used pieces of the edging attached at factory points, then used the plugs you see in the pictures. It's also held to the factory plastic under tray using the plastic pushnuts. It worked out well and became one of those projects where simpler worked better. :-)
What are your thoughts on the Gurney flaps?
Kach, I will look up your threads to see what you've been working on.
