Air-take verses direct hho injection into manifold
Air intake or PCV injection:
My question to think about is this - most information tends towards air intake injection .I have an issue with this due to the PCV system also drawing air from the air-intake .The science behind the mixing of hydrogen and oxygen with crank gases is possibly endless and not the real question .
In my case I have a modified intake with a performance Cone filter directly onto the throttle body .
The HHO is currently injecting into the center of the cone via a chassis through fitting .
During de-acceleration and long downhills at low speed as well as any other time the foot is off the pedal - what will happen - the butterfly closes and only a small portion of air is actually pulled into the manifold.I assume at this stage the excess hho will be lost to vent to atmosphere.
So the question would be this - would placing the hho into the manifold be more beneficial and provide better gains as it is constantly being used in opposed to air-filter intake where possibly only a portion is actually used.
Anyone done a more scientific look into this one .
My PCV is venting to atmosphere so I do not have PCV injection option - however I will be adding a fixed connection in place of the PCV valve to inject direct in future to make my own observations .
Thanks
Bradley
