Old 01-20-2019, 06:46 PM   #3304 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by 02BMW02 View Post
Many Thanks thingstodo,
I so hope this controller works for me, Ive had a run of back luck with controllers, have gone through two can bus controllers and Pauls drop in leaf board controller nothing worked, Paul has told me that there must a fault on the leaf main circuit board.
Ironically the board that I'm building was the first board I bought from Paul.
What version board to you have ? I have Ver 0.4
What setup are you running any pictures ?
I know you build your system a while ago.
I don't understand how to connect J43 & J44 "high voltage DC monitoring", do I need to wire resistors in series here ? eventually I will be using a Leaf pack 360V
I found a version on the AC board - 1.0 ... but it is likely within the first 5 he built.
I have a couple of controller boards that I got from Paul to do the brain transplant thing on industrial AC drive. They are version 0.3
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
