Old 01-21-2019, 11:12 AM   #28 (permalink)
Angel And The Wolf
Originally Posted by ksa8907 View Post
Will the stock heater also try and run or is there a way to defeat it?
The stock heater will only run if you switch it on, but if you need it to keep the windows defrosted,you should be able to rewire the heater away from the Leaf battery, and run it on an auxiliary generator, and if your aux gen is liquid cooled, you should be able to put it's radiator in the car for heat.
https://www.alibaba.com/product-deta...7945617enxOjZW
