Old 01-22-2019, 06:05 PM   #18 (permalink)
ratgreen
Ive got a om606 merc I run on veg. In this temp I add 5-10% petrol to thin it out, as well as add 2ehn to raise the cetane back up.
om606 has a factory fuel/coolant heat exchanger build into the heads so I didnt have to worry. If yours doesnt I'd get one. I also have a 12v sillicone heating pad wrapped around my fuel filter to help warm it up before the engine has got to temp.
'98 OM606 E class Merc
Running on veg oil
35mpg average (tank to tank)
225 45 17 > 215 55 17 @ 55psi
LED lights all around inc headlights
Planned: electric turbo turbine generator (WIP), EGR coolant heat exchanger, Front air dam, solar panel, lithium battery pack, alt delete, full undertray, weight reduction, block insulation, engine bay insulation.
The Following User Says Thank You to ratgreen For This Useful Post:
320touring (01-22-2019)
