Old 01-23-2019, 06:21 PM   #20 (permalink)
aerohead
Redline
I was poking around today looking at different gear oils. The 2014+ Mirage calls for a 75W80 gear oil. The 75W is the engine viscosity when cold, and the 80 is the viscosity when its hot. All oil is substantially thicker when cold, so getting a low first number is a good thing as it will always be thinner when hot. You just don't want it to get too thin, or you can accelerate wear in your transmission. Here is a chart to help illustrate things.
Therefore, I was looking to see if I could get a 70W80 or even 65W80. Alas, I can not find anything like that. However, what I did find was Redline MT-LV 70W/75W. You'll notice this doesn't follow the normal naming convention. So, I'm not exactly sure what to think about it. It is quite a bit thinner than Redline MTL 75W80 that many here have used.
Here are the viscosity specs of the two:
75W/80 (OE spec)
Vis @ 100°C, CSt 10.2
Vis @ 40°C, CSt 50
70W/75W
Vis @ 100°C, CSt 6.5
Vis @ 40°C, CSt 9.8
For reference, 40C is 104F. That already seems warm for a manual transmission, but I haven't measured my transmission's temperature. Anyway, at 104F, you can see the 70W/75W is 5 times thinner than the 75W80 oil. Thats a heck of a lot less churning going on. Less churning means more power and efficiency.
Anyways, I post this info because I am thinking about using it in the Mirage. I have contacted Blackstone Labs, a third party oil analysis company. I've asked them how they recommend I proceed with testing this oil with minimal risk to my transmission. I've used them many times in the past for engine oil analysis and they're very helpful.
I tried this in the CRX and could not discern any improvement to mpg.
Also,I put a number of baby jars filled with various viscosity standard and synthetics into the freezer,and next day,did a simultaneous side-by-side tip-test,flow comparison,and the standard Valvoline 10-40W flowed just as well as the most expensive full-synthetic.
You may have a better experience.
Daox (01-23-2019)
