Old 09-04-2008, 08:49 PM   #11 (permalink)
Stealth TDI
Diesel Fan
Stealth TDI's Avatar
'98 Stealth TDI - '98 VW Jetta TDI
90 day: 47.05 mpg (US)
Send a message via AIM to Stealth TDI
Hello,
I appreciate the input. As I considered, it appears the risks of bondo failure is not worth the gain. In addition to spinning forces, potholes, heat transfer, and other variables may exceed the limits of the bondo. My FE numbers are not consistent enough to do any direct comparisons between open holes and taped-over holes. So I'm not sure about considering the tape. Also, my car is a bit of a show car. So I'd want whatever I choose to look pristine.
What I still don't know is if smooth wheels yield significant results or if it is one small step of many to achieve significance. Regardless, I will hold off for a while and test my options later.
Originally Posted by Sandy View Post
Not to hi-jack this wheel cover thread,
but here is a picture of my "grand-daddy" hf antenna.
http://www.yankeecruisah.com/w1cgs/p...-rear-side.jpg
I have my eye on the the Sidekick. I'm saving up for one 'cuz the ATAS sux. I will stay with a center mounted location to perhaps hide some of the antenna behind the draft of the cabin for (hopefully) slightly better Cd.
Take Care,
Scott
'98 Jetta TDI (puff, puff, pass...)
