Old 01-25-2019, 04:59 AM   #14 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I agree that one bolt is a bad idea.
Maybe try tapping threads into the trans case and use a shorter, but thicker bolt. Maybe 12mm or 7/16 threads? While the bolt should go into the engine block, I think it'll be OK if it doesn't. You'd probably have to enlarge the hole in the starter for the larger bolt.
Or have the broken bolt side of the starter welded to the trans case.
Or always park on a hill!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
California98Civic (01-25-2019)
