Old 01-25-2019, 10:24 PM   #27 (permalink)
oil pan 4
Have you looked at the charge difference between 120 and 240v power on the same charger?
Notice how 120v charging takes more than double the time to charge.
Why do you need a 10kw generator you can get evse units that oitput little as 8 amps.
Even my lowly converted Panasonic made granny charger will do about 2.9kw. A 7kw generator should be able to handle that no problem.
