Old 01-26-2019, 12:54 PM   #173 (permalink)
IamIan
IamIan's Avatar
Originally Posted by Stubby79 View Post
Any reasonable option(s) to keep the li-ion warm
So, for 4+ months of the year I'd need either a battery heater, or to disable the alternator until the battery has warmed up.
I've been playing some with the Panasonic's U-Vacua Vacuum Insulated Panels (VIPs).
R45 insulation in only 15mm thick.
R66 Insulation in only 24mm thick.
DigiKey is a distributor for Panasonic so you can get them from them.
Not all that expensive for the amount of insulation R value they offer.
With that much thermal insulation effect .. you could vastly reduce the amount of energy needed to keep them warm .. even in 0F outside temps.
Any recommendations on a 12v warmer with a thermostat? So far the only systems I've found are 120v.
What about PTC based heating element.
They self regulate around the temperature point.
Can design resistance around whatever voltage you want.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
Ecky (01-26-2019)
