Originally Posted by kach22i
Was the side panel ducting to increase efficiency because of the blocked off upper grille?
From that thread:
https://ecomodder.com/forum/showthre...n-17232-2.html
Did you ever get the cooling issues resolved?
I am not a fan of grille blocks because I had some scary moments of near overheating when the weather and or traffic changed plus once a fan controller failure forced me to pull over.
Not so much due to the grill block, but in general just to direct all the incoming air to the radiator.
The cooling issues got resolved with a new radiator/coolant flush. After pulling the old radiator I back-flushed it and got some nastiness out. The fans would only kick on if stuck in traffic with the new radiator/coolant.
That car is long gone, one day the trans decided it didn't want to disengage the parking pawl when I put it in gear (my best guess anyway). It had been sitting for about a month due to a seized AC compressor so I suspected the brakes were sticking when I tried to back up. Gave it some gas, heard/felt a big clunk, and ended up with trans fluid on the driveway.
