I have an Etek motor that I bought about 10 years ago that I am finally just getting running on a test stand.
So first, there are no positive and negative on the terminals, can you hook it up either way, with it just changing direction?
Also, there's a little squeaking if you turn it in one direction so I'm a little worried that all the grease or whatever was used for lubrication is dried up, is there any maintenance I can do after having it sit for so long? For those not familiar with the motor, this is it:
Robot MarketPlace - Etek Motor
Current plans are putting it in a go-kart with 3 12v motorcycle batteries
