Old 01-31-2019, 11:41 AM   #22 (permalink)
Piotrsko
More ground clearance doesn't necessarily mean higher ride height, just the lowest point of contact is something to do with the 4wd system. I would bet the frontal aera on a 4wd version is greater than a 2wd version.
Ok then, how do you avoid the higher ride height if all the other factors tend to remain the same
