Originally Posted by Hersbird
More ground clearance doesn't necessarily mean higher ride height, just the lowest point of contact is something to do with the 4wd system. I would bet the frontal aera on a 4wd version is greater than a 2wd version.
Are you talking about the use of a bigger/lower rear differential (
commonly the lowest point) or actual body and suspension lifts?
Body Lift vs. Suspension Lift
