Old 02-03-2019, 07:44 PM   #9 (permalink)
cRiPpLe_rOoStEr
Originally Posted by niky View Post
Properly fitted, water injection saves fuel on diesels. But I don't think you can guarantee fuel savings on ALL diesels without at least some ECU tweaking.
Even in a mechanically-governed Diesel engine, some higher amount of moisture suspended in the air already leads to some enhancement to the efficiency.
On gasoline, it might help on turbo cars, but from what I've seen, the effects on economy gasoline engines is minimal... usually a nominal power bump, if any, and at a level that doesn't justify the price of installation.
With the EFI trimming the fuel to keep power and torque figures at the stock parameters, the cooling of combustion chambers provided by that small amount of water allows a slightly leaner burn even in a naturally-aspirated gasser with port injection.
