You can't build on the curb, so you would have to build on the slope part. Instead of raising the slope to level it, I'd scoop it out to create a large enough level pad lower down, then build a two story house with the second floor main level at street level.You probably want your garage floor on solid ground, not above a lower floor room, so, some of that dirt you remove for the two story can be used to raise a portion for a street level garage.
