Old 02-07-2019, 09:22 AM   #206 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Sounds like you need a low voltage cut. Maybe if you're starting current is low enough with the caps you could find a low voltage cut with an appropriate rating.
https://www.amazon.com/Volt-Voltage-.../dp/B00KI1Z8TY
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
